Question about Onkyo TX-SR605 Receiver
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player) still working properly. We can't even think of anything else to check as to why is would say it is not getting the signal. Cable box still getting cable, otehr tv's in house work and cable says it is recording programs currently. Any suggestions of other things to check, reset, etc?
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
Posted on May 31, 2017
SOURCE:
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
  • 6 Answers
SOURCE: cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Posted on Jan 09, 2008
  • 440 Answers
SOURCE: onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Posted on Feb 03, 2008
  • 1847 Answers
SOURCE: My onkyo tx-sr 605 switches
there seem to be issue with the power supply.
Posted on Oct 12, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Hi I have just connected my onkyo tx-sr 507 everything works perfectly apart from the monitor channel I have used a composite video cable to one of the inputs on my tv from the monitor output while using...
The 'monitor' video output would go to a corresponding composite video input on the TV/monitor. It would be selected as a source, not a channel. I'm sure the unidentified video device's manual explains it. Any RCA cable would suffice.
Aug 08, 2011 | Onkyo Tx-sr507 A/V Receiver
Loss of audio from onkyo 605
If the settings are correct, then it is just like the 605 I had, its broken. Get one made by someone else if the warranty has expired on it. I suggest Pioneer.
Apr 06, 2009 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Oct 24, 2008 | Onkyo TX-SR605 Receiver
Dont understand
this is retarded comment .... 20 what is 20 ? this is not how we compare receivers.... you ****...
May 09, 2008 | Onkyo TX-SR605 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
Onkyo tx sr 605
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
941 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
