I'm sorry, but I don't have access to specific assembly instructions or parts lists for the Natart Rustico crib and bed. However, I can provide you with some general guidance on assembling cribs and beds based on common practices. Please note that these instructions are general, and you should refer to the specific assembly manual that came with your Natart Rustico furniture for accurate details.
General Steps for Assembling a Crib:
- Sort and Identify Parts:
- Lay out all the disassembled parts and sort them according to their shapes and sizes. Identify key components, such as crib sides, mattress support, hardware, and any decorative elements.
- Follow the Manual:
- Refer to the assembly manual that came with your Natart Rustico crib for specific instructions. The manual typically includes step-by-step guidance and illustrations.
- Assemble the Frame:
- Start by assembling the main frame of the crib. Connect the crib sides to the headboard and footboard using the provided screws and bolts.
- Attach Mattress Support:
- Install the mattress support platform according to the manufacturer's instructions. This usually involves attaching it to designated points on the crib sides.
- Secure All Connections:
- Tighten all screws and bolts securely. Ensure that the crib is stable and does not wobble.
- Install Drop-Side Mechanism (if applicable):
- If the crib has a drop-side, follow the instructions carefully to install the mechanism securely.
General Steps for Assembling a Bed:
- Identify Parts:
- Lay out all the parts for the bed and identify the headboard, footboard, side rails, support slats, and any additional components.
- Use the assembly manual provided by Natart for specific instructions. Follow the steps outlined in the manual for your particular bed model.
- Begin by connecting the headboard and footboard using the provided screws and bolts. Attach the side rails to complete the basic frame.
- Attach Support Slats:
- Install the support slats according to the manufacturer's instructions. The slats typically provide support for the mattress.
- Ensure that all screws and bolts are tightened securely. Check the stability of the bed frame.
- Attach Additional Components (if applicable):
- If there are additional components, such as decorative elements or storage features, attach them according to the instructions.
Parts List:
For a precise parts list, please refer to the assembly manual that came with your Natart Rustico crib and bed. The manual should include a detailed list of all components with corresponding part numbers.
If you do not have the assembly manual, you may contact Natart directly or check their official website for customer support. They should be able to provide you with a replacement manual or offer guidance on assembly.
Always follow safety guidelines when assembling furniture, and if you're unsure or uncomfortable with any step,
I need instructions on how to assemble our orginal co-sleeper. We purchased if off of ebay and the instructions were not included. Please help.
