In order to reset a phone you can look for the steps depending on the model of your device from this website: How to perform Master Reset Master Clear, but you can follow the steps from your specific phone from here: Linux Java Non Touchscreen Master Reset Master Clear
What is Phone brand and model? you can reset the Phone using the master reset code,you can get the master reset code from here Classicunlocking.com and reset it,i have reset my phone nokia 6600 from security lock using the master reset code.You can get the master reset code for Nokia and Alcatel Phone there,Before Getting the master reset code you try some Default code 1234 or 0000 for Nokia and reset it.If not work get the master reset code there.
you forget the security code means get the master reset codefor that one, master unlock code is a code that completely resets your phone, removing any securitly locks , get the code my hand set name lava arco3
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3: 1. Open your phone up and go to “Settings” 2. Next go to the selection for “Initial Setup” 3. Next go to the selection for “Master Clear” 4. Then select to confirm the option. 5. Now enter the security code which should be “000000” 6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post: hard reset motorolla razr v3 hard reset razr phone wii master reset hard reboot motorazr how to hard reset a razor v3 master reset code for motorola v3 master reset code razr v3 master reset for v3 via pc master reset motorola razr 2 master reset v3 razr with white screen motorola v3m master reset p2k commander razor master reset razr 3 and how to reset razr master reset ebay razr master reset password razr master restart razr screen master reset reset razr reset razr to factory reset razr v3 to factory v3 hard reset razr v3 razr reset hard boot
You have the option of using Master Reset or Master Clear to reset settings, and remove information. Master Reset resets all settings on device to factory default. Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc. To perform a Master Reset or Master Clear:
Press Start.
Scroll to and select SystemTools.
Scroll to and select either MasterReset or MasterClear.
