Philips Magnavox MWR10D6 DVD Recorder Logo
Posted on Jun 07, 2008
Dvd recorder mwr10d6
I cannot find my user's guide. i would like to record movies from my tv and dvr onto a dvd disk using my magnavox dvd recorder.
please direct me to an online user's guide for this model.
thank you
bo
  • Anonymous Jul 26, 2008
    Thanks you this was quite helpful for me as well.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jun 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
817
Points
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) hope this helps!
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
2answers
Editing DVD RW disks
What soft did you use?
1helpful
2answers
Hello, I have a Magnavox DVD Recorder mwr10d6. I want to burn some movies to play in it. What format of CD's do I need and does it matter if it's avi, mpg, mov, mp4 or not. What are these anyway? Thanks!
avi, mpg, mov, mp4, these are all video files. you can use almost any cd-r band. dvd movies require use of dvd-r disks. some dvd-r disks are not playable in all players.
I have a magnavox mwr10d6 recorder. Errors keep coming up cannot record on disk e454037380
The disk might not have been finalized in the program that it was recorded on. If this is not the case unplug your recorder for 60 seconds and then plug it back in this resets the recorder.
1helpful
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
1helpful
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
2helpful
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Hope this helps!
How to set up my magnavox dvd player / recorder
http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Magnovox Dvd Recorder closing out disk
Put the disc back into the recorder.
Goto the setup menu.
Select Disc Edit. Press OK
Select Finalise. Press OK
Your DVD player is made by Funai (for future reference)
The User manual can be downloaded HERE. You need page 38.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
