SOURCE: step up
it should be possible i did that with one of my comps before...ummmm yeah you can im almost possitive, good luck and happy computing
SOURCE: i have gigabyte motherboard H57M-USB3
It should be, it says this about your memory support.
Here is a list of compatible memory for that motherboard
http://memoryselector.cnetchannel.com/tigerdirect/results.asp?hvhBlBE0fe0AED
SOURCE: I have an Asus M4A88T-M
please tell us if there are any beep or no try to take off the ram and listen is hear any sound , finaly if didn't hear any sound that mean one of three
1- bios need to programed 80%
2- cpu is damaged 5%
3- mother board is damaged 15
if you see that is helpful please don't forget to vote me
best regards
SOURCE: I have a ASUS P8P67
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
