I accidentally locked in the factory settings in setup, how do I unlock them?
I can't aqdjust anything now, color, brightness, etc
On the remote, hit the "Menu" button and then press the down arrow until you see "Picture," then hit enter, now hit the down arrow until you see "mode" and hit enter again. You should then see "power up" displayed. Hit enter again to get to the setting choices where you can change the mode back to "home" (hitting enter one more time) then exit the set-up menu.
To Debris Field,
YOU ARE THE BEST!!!!!
For month, we were not able to set our TV.
Wow, do you have a paypal because I think I want to send you $20!!!
thank you very much now my children can stop telling me off about me messing with the menu button, thank you again.
I know it might be late, but just change your settings in the power up menu to HoME instead of showroom.
Debris Field, thank you!! Thank you!!! I am very tech saavy, but this one had me stumped for a few hours. I'd buy you a beer if you weren't just an avatar on a website! :-)
• Unlock all of the channels on the TV by
entering "6688," which is the factory reset code. This code resets
the TV to original factory settings. Once this is done, you will have to go
through the initial setup.
• Call Omni technical support at (416)
260-0047. A technician can help you troubleshoot the television as the problem
may not be the child lock. You'll need to know the model number and serial
number of the TV.
•Take your television to a TV repair shop if you
are still unable to unlock the TV. The problem may be with the wiring, so the
repairman may have to rewire the TV
apple7-I have the same problem on a 226-s12 (V) 26" that all of a sudden won't let me select certain settings including home mode!!
Im having the same problem but i dont know how to get back into my power up menu. Can somebody help me out please
