How can i print in mirror image
The simplest way to do it if the feature is not supported in your printers driver (most do not feature the option) is to nmirror the image in a graphics package such as Photoshop.
It's easy enough to do and once mirrored simply print it as normal and the image will still be reversed on the print out.
SOURCE: Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
SOURCE: Printer is printing job as a mirror image
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
SOURCE: how to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
SOURCE: Is it possible to take mirror image printing using by HP Laserjet 1022
That works as the Driver and application( End user is using) settings.
This can be done from software not hardware.
Have the same problem with my HP7310. Alternative solution is to print it out normally and the do a mirror image copy. While it cannot print mirror image, it can copy mirror image.
