IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
