RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put in battery green light came on as normal, and strip of nails, gun fired once and light shut off, and will not work at all, what could be the problem? thanks
Anonymous
Level 3:
  • RTO Master 43,501 Answers
  • Posted on Mar 06, 2011
Anonymous
RTO Master
Level 3:
Answers
43501
Questions
0
Helped
10835294
Points
101584
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Nail gun does not fire but can smell gas
1.Clear Jams. ...
2.Inspect Your Air Supply. ...
Reload the Magazine. ...
4.Clean the Instrument. ...
5.Replace Seals and O-Rings. ...
6.Inspect for Harm. ...
7.Take It to the Help Place.
Consider https://lumbuy.com/ for buying best quality Nail Gun Machine.
1helpful
2answers
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
The driver on my Stanley 18 ga. finish nailer( SB- 1664FN ) is not retracting sufficiently ( or at all )to cycle another nail forward. I have tried to keep the gun lubricated. I have gently pushed the...
Remove the 4 screws and pull cap off .careful not to rip the gasket and pay attention to how the head valve sits. Pull driver out to make sure its not bent . If its fine put driver back in place. Remove the head valve from cap . Replace the oring around the head valve part # 180535 . If thats not a option take a thin strip of teflon tape and wrap in around head valve once then put old oring over it. Grease or oil , put cap back on and test fire. Should be good to go . Best of luck !
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
1helpful
My paslode impulse framing nailer quit working. It fired and the fan shut of prematurely then it would not fire and the fand would not run. The blinking green LED light in the handle is blinking green...
It sounds like the contacts in the plunger are dirty or bad. Or even a wire for the contacts is loose. My guess is when you took it apart to clean it and replace the Orings you had moved the loose connection so it worked for a minute. On mine, I went all through the gun only to discover the wire feeding through the gas chamber was squished and broken inside. The wire's plastic insulation did not even have a hole in it. If you take it apart again check the wires carefully, check the contact points to make sure they are clean as well.
Another note, my father had issues with his and we went through it with a fine tooth comb. In the end we discovered it was a dirty contact in the gun where his battery hit. The battery itself was fine but once we cleaned the batteries terminals with a pencil eraser and plugged it into the gun we noticed one of the contacts had black stuff on it from the contact inside the gun. Works great every since.
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
1helpful
2answers
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Top RTO Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
