Why did fuse blow?
Is timer under-rated for load on line?
Do wire size and breaker size match?
EJ500 is rated incandescent-only with maximum 500 watts, with temp range from 32 to 104 F, maximum distance 100' from load, and timer has 1 year warranty against defects.
http://waterheatertimer.org/Intermatic-timers-and-manuals.htmlhttp://waterheatertimer.org/Color-codewire.htmlTry resetting timer.
This will delete both programs and current time settings.
Hold down on-off button, and press and release reset button.
Keep holding on-off button until display changes, and 12:00 is flashing.
If timer will not reset, try changing battery.
Simple power outages, and blown fuses can cause power surge that will knock out timers. This is a common problem, and resetting timer can usually solve problem.
Timers like outdoor power pack, and analog plug-in timers do not have reset button and can easily fail after ordinary power outage.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
