HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
Anonymous Posted on Oct 23, 2010
Hp compaque presario f700 sometimes working but most of the time always restarting and no display. what is the problem?
Brian Sullivan
Level 3:
  • HP Master 27,725 Answers
  • Posted on Oct 23, 2010
Brian Sullivan
HP Master
Level 3:
Answers
27725
Questions
Helped
5668952
Points
79191
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Not booting hp presario f700
hit the f5 key then follow the screen from there that is in safe mode
Broadcom wireless works sometimes
Move the laptop closer to the wireless tramsmitter if it works most of the time then you can get a booster.
Terry
1helpful
2answers
Need sound and video drivers for HP compaq presario F700 F710EE
Follow this steps
1)go to this link
2)enter your product name/number
3)select your product
4)select your operating system
5)select driver audio
6)click on download button
7)run downloaded file
8)install driver
9)restart your pc
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
2helpful
Compaq presario F700. Display screen is garbled and illegable most of the time. Occasionally it will come up perfectly normal and clear but majority of time its a bunch of multi colored lines flickering....
Since the problem you describe is intermittent I would first suspect a loose or shorted electrical connection. To check this you will need to take the computer apart. Step by step photos of this procedure are at http://www.insidemylaptop.com/disassemble-compaq-presario-f700-notebook/ .
Once you have access to the lcd cable you can check its connection and the condition of the cable itself. If the connection is secure and the cable looks good you probably have a bad lcd.
2helpful
1helpful
2answers
HP Compaq f700 Laptop keeps on restarting without any display. No problem with HD and RAM. Problem reoccured even after replacing display chip. Please help.
try removing battery and small watch battery and disconnect power for 10 min then replace and restart. If it comes back on it will do it again when you turn it off, so don't, lol. I have this problem and everyone says these have motherboard problems. From what I can see they don't remember bios on startup. I'm still searching, Hope this helps.
Compaque presario 2000 - hibernation button problem
Go into the control panel and under power options, change your settings.
2answers
My webcam doesnt work compaq presario f700
hi..
you have to download the drivers from your computers website...to find out the model of your computer > system tools > system information..
thank u
rate me!!
Ethernet Controller f700 always error
Download from following link.Just select your operating system and download the latest version
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=99905&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=96403
Thanks
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
