HP Broadcom NetXtreme Network Adapter Logo
Posted on Oct 23, 2010
I have lost my Local internet Connection on my Laptop and i need the driver that will solve this Problem
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 37 Answers
  • Posted on Oct 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
37
Questions
Helped
7091
Points
96
Check the hp website they usually will have all drivers for things that are compatible with an hp computer along with products that they create. If it is not found on there try www.downloads.cnet.com.
Wifi Connection/Capability is lost
go to the laptop's home page, download and install latest drivers
When i removed some installed programs in my
Hi. I think what you have remove on your laptop is the driver for your broadband connection, the best way to solve your problem is to contact your Internet Service Provide to ask for the drivers or you could download it yourself over the internet. Just go to the manufacturers website for your machine and go to the tech support or driver support are and download the latest driver for the wireless and Local Area Connection and install it your computer. Hope this helps
Internet connection
Dear Sir,
plz folow this step
For XP-> go to your control panel -> click under network connection -> right click on Local Area Connection and disable it -> right click again to enable it back.
For Vista-> go to your network and sharing center-> click under manage network connection located on the left hand side -> right click on Local Area Connection and disable it -> right click again to enable it back
if the probelm not solved then give IP address manualy for internet above same processdure
Cant connect to lan modem
1. check first your lan connections,
click start, go to control panel, click network connections din check your local area connection.
2. right click the local area connection, then try to disable and enable it.
3. if not been solved,
try to look the driver of your ethernet drivers
look at and search your motherboard's brand and model then search it and download for your drivers for your network adapter.
or you may try this,
1. right click my computer
2. click properties
3. clcik hardware tab
4. click device manager,
5. click network adapter
6. right click the name of your network adapter then, click update
Just changed from computer connection to a sony laptop and also changed my internet supplier to talk talk, printer has stopped working can you solve this for me?
Your internet connection won't have any effect on the printer so it has to be the laptop.
Disconnect the printer and install the drivers from CD. Reconnect printer when asked.
This should solve it.
1helpful
Local area connection icon disappeared after formatting?
Please see this link. You will need to download and install the drivers for your network adapter. You can download these from either the manufacturer's website or the motherboard or network card mfr's site. Please see this tutorial on how to do this.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
DRIVERS PROBLEM
You can download the drivers for your model laptop from the Compaq WEB site, their support/download page. Make sure you download the Vista version of the drivers.
http://www.compaq.com/cpq-country/cpq_support.html
You will need to use a computer that has Internet connection, when you have downloaded the drivers, copy them and install them on your laptop.
Local internet connection on dell laptop
i assume you are connected using wired or ethernet connection on a modem or with a router...? try to release or renew your IPs also what's the OS of this laptop? if it's on windows, run ipconfig from the command prompt, if you got an IP starting with 169.xxxx....
release and renew it. if it's a Mac, trash tcp/ip.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
