Xante Accel-a-Writer Laser Printer Logo
Posted on Dec 15, 2017
Accel-a-writer 3g feed problem
I am trying to use autotype delta film for silkscreen. The film will not feed thru the manual feed in the printer even with the drive set on thick transparency/film. I also have trouble with 32# paper, but regular 20# paper feeds fine. This is a printer I bought recently on ebay. Any ideas?
Sue
2 Related Answers
Anonymous
  • 667 Answers
  • Posted on Apr 03, 2008
SOURCE: accel-a-writer 3g for leopard
Yes. If you need the driver here is the link. Just scroll down to operating system and choose Mac OS X. If this takes care of your problem please rate as fixed. Thanks.
http://www.xante.com/support/aw3g/
Anonymous
  • Posted on Jul 28, 2009
SOURCE: Film postives for screen printing
Try running the film through the printer with no image before imaging with graphic. The film will be "pre shrunk" so that when the image is actually printed on the film, the shrinkage will be minimized. This should work unless it is a roller slippage issue.
Xante 3G - indicates 'print' then constant 'front paper jam' (any size)
That is cause the paper feeder is not working properly. It could cause the roller that feed the paper wear out or a bad tray release selenoid
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
2answers
Is there a driver for Windows 7 for Xanta 3G
check it at Xanta accel a writer 3G lasr Print homepage
1helpful
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Xante Accel-a-writer 3N Printer Not responding
I just signed up today. Are you still having the responding
issue?
Accel-a-writer 3g for leopard
Top Xante Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
