Question about Sony KV-36XBR450 36" TV
Hi, at power on via either method (remote or manual button press) I get audio but no screen image, except maybe 1 out of 25 tries, then it works fine...short of not turning it off what's up. I have removed all other power draws from the socket, pulled the plug and let it completely power down....I think the main circuits that get powered up are not getting enough juice to kick them into a higher state to correctly power on the CRT sweep...I have no problem cracking the back open and working inside (solder new power supply or resisters?)...suggestions TV is Sony KV - 36XBR450
    Problem Solver:
  • 5 Answers
You have a FLASH BACK problem.. just replace FLASH BACK and POWER SUPPLY BOARD and your good to go..
Posted on Oct 23, 2010
SOURCE:
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Help pls - toshiba 40bl702b Silent / No sound for a week!
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 24, 2015 | Toshiba Televison & Video
I need the remote codes to make my proscan tv work with dish network. Can you supply them?
Method 2 of 3: Scan for Code
  1. 670px-program-a-dish-network-remote-step-6-version-2.jpg 1
    Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. 670px-program-a-dish-network-remote-step-7-version-2.jpg 2
    Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. 670px-program-a-dish-network-remote-step-8-version-2.jpg 3
    Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. 670px-program-a-dish-network-remote-step-9-version-2.jpg 4
    Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. 670px-program-a-dish-network-remote-step-10-version-2.jpg 5
    Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
    • Do not press the arrow buttons too quickly, or you might skip over the correct code.
    • The mode button for the device will flash rapidly 8 times when you have scanned all the codes for that device.
  6. 670px-program-a-dish-network-remote-step-11-version-2.jpg 6
    Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. 670px-program-a-dish-network-remote-step-12-version-2.jpg 7
    Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
Method 3 of 3: By Menu
    Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • The menu screen should show on your television screen:
    • 670px-program-a-dish-network-remote-step-14-version-2.jpg 2
      Select Settings. Locate and select the Remote Control button.
      • The Remote Manager screen should display on your screen:
      • 670px-program-a-dish-network-remote-step-15-version-2.jpg 3
        Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • 670px-program-a-dish-network-remote-step-16-version-2.jpg 4
        Select the Lookup Code button:
      • 670px-program-a-dish-network-remote-step-17-version-2.jpg 5
        Select the sort criteria and device brand. Then click the Next button:
        • Test the device at this point. If the remote works as expected, select the "Yes" button; otherwise, select "No" to try the next code in the list.
        • Repeat this process until a working code is found, or continue by selecting "Enter Model" to find the device code.
      • 670px-program-a-dish-network-remote-step-18-version-2.jpg 6
        Enter your model number in the search field. You can enter all, or part of the number.
        • Select the device model number from the list, then select Next. Test the device. If it works, you're good to go! If not, and you've tried all the other methods, your device is not supported with the Dish Network remote.
Sep 09, 2014 | Televison & Video
How do I get the remote codes to make dish tv remote working?
  1. Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
  6. Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
  1. Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • Select Settings. Locate and select the Remote Control button.
      • Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • Select the Lookup Code button:
      • Select the sort criteria and device brand. Then click the Next button:
      • Enter your model number in the search field. You can enter all, or part of the number.
The parking brake on my xdvd8182 doesn't work, im thinking a broken wire. Ive tried the codes, grounding with a switch and hooking up to e brake
It is illegal and unsafe to watch the monitor while driving. I assume this is needed for an RV or something.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Feb 24, 2010 | Dual XDVD8182 Car DVD Player
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
How do i bypass the parking brake switch in order for my video to play
** Go to the Menu
Credit: DKA
** Insert Audio CD
** Press PLAY
** Press ENTER
** Insert a DVD
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Feb 09, 2008 | Televison & Video
Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Sony KV-36XBR450 36" TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
