Question about La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor
Atomic clock radio controlled with date, indoor and outdoor temperture and moon, lost my manuel - it;s set on military time needs to be central-6118
    Brigadier General:
  • 8,546 Answers
Is it one of these?
http://www.klockit.com/PDFs/lacrossemanuals/WS-8157NU.pdf
http://www.klockit.com/pdfs/87135.pdf
http://www.klockit.com/pdfs/87136.pdf
BTW, 24-hour military time and time zones are independent functions.
Posted on Jan 19, 2011
SOURCE:
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
How do I change the time zone?
Radio controlled atomic clock self sets, and self adjusts automatically. This clock is very easy to use!,Daylights Saving Time on/off option; 4 Time Zones - Pacific, Mountain, Central, or Eastern,Folds into smaller size for easy storage and travel; travel pouch included,Automatically sets day, date and time; 2 separate alarms - great for weekends,Sturdy, contemporary construction. Stand folds for easy storage. 2x AAA batteries included; as shipped to U.S. Government and institutions
Oct 13, 2014 | Marathon Genuine Atomic Travel Alarm Clock...
I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
http://www.skyscaninfo.com/content/manuals.html
Jan 03, 2011 | Vacuums
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
Manual Information/Owner Guide
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
Want to set the clock
Each time you press the set button on the back it selects one of the items that you can set. For example if the "month" is selected by pressing the "set" button then press the "+" key to change it from 1->2->3->4 etc. Each time you press "+" key the month will go up by one. Stop when you reach the correct month. You can do the same for each item including the time zone and daylight savings time and whether you want your temperature to be in Celcius or Farenheit. Hope this helps...
FixerUpper
Sep 15, 2007 | SkyScan 86709 Atomic Wall Clock
La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor Logo
654 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
