Canon ZR80 Mini DV Digital Camcorder Logo
Posted on Oct 22, 2010
Inserted the mini DV tape in Backwards, the tray partially closed, trapping the tape inside, I cannot get the tape out using "reasonable" force
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Oct 25, 2010
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251230
Points
49
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
1helpful
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
20helpful
2answers
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
10helpful
2answers
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Mini dv
mam try to check the tape if its correctly inserted to the camcorder. it must the tape itself or the tape compartment has the problem. insert the tape and see if its feed to the tape head and be sure that it will close with no problems. if the problem still occuring or persisting then try another dv tape and see if you got the same problem. otherwise go to the nearest repair shop to be able to fix with the use of their tools. hope that helps you ma'm!
thank you for using fixya
CHARCOIS
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Sony Camcorder Mini DV tape doesn't go in
Have you cleaned the tape deck at all? That might work.
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Not loading tape
This is the sensor. Not a cheap repair, but something you can live with as long as the camera is still working for you.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
