Whirlpool LGB6300 Gas Dryer Logo
Posted on Oct 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum does not rotate - Whirlpool LGB6300 Gas Dryer
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Oct 22, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10835089
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have this error on my canon 2202N E010-0000 , please any solutions ?
That error indicates a failure in the rotation of the main motor . Please check if the drum unit rotate normally. Just remove the drum unit and check rotation. If drum unit is good, check the main motor
2helpful
2answers
What is an L4 error code on a Kyocera Bizhub machine?
This means that one of your drums has exceeded its life cycle (carries toner from the cartridge) and generally run around $100 +/- to replace.
My bosch nexxt500 wont rotate the drum, the water pump work but the motor doesnt rotate the drum
Check if the lid isnt working as this prevents a roration . Else must be a loosened or broken belt that rotates the drum as the motor works . Hope this helps
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Screw stuck behind drum making it not rotate
You will need to remove the drum and assembly, please check on this link for tips: Drum removal
2helpful
3answers
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 • Dryers
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
