SOURCE: Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
SOURCE: icing up
i have had to clear the drain hole 3 times now. I believe the ice build up is caused when the door is left open and too much frost builds up.
It is a pain to keep doing this. I check the defrost cycle and all fans, etc. appear to be working.
It seems to me that the problem is the metal flashing, which doesn't direct the water down the drainage hole sufficiently.
