The screen appears in a tripple immage, that is a lot bigger than the screen. I can not see whole desktop on the screen and i can not setup the immage. If was a normal desktop i was simply setting up the dimensions on the screen... Here i do not know what i have to do to let me see all the desktop...
Visit
cutepdf.com . Click "Free Download." A box will
appear asking, "Do you want to run or save this file?" Answer with
"Save." The download will begin. Download Ghostscript (see link in
Resources). Look for "You Can Get the Free GPL Ghostscript 8.15 Here"
sentence and click "Here." This download is required for the CutePDF
program. Save the GPL Ghostscript file to your desktop.
Double click the "CuteWriter" icon on your desktop once your
downloads are complete. Click "Next" on the Setup - CutePDF Writer
screen. Click "I Accept the Agreement" on the License Agreement screen.
Click "Install." The CutePDF setup will run. Click "No" to the CutePDF
Writer Setup box that appears next that asks "Would You Like to Download
the Converter?" You have already downloaded the converter. Once the
setup is complete, a Readme.htm file will appear in your Internet browser. Read this file or print it.
Double click the "Converter" icon on your desktop (it will
have a black "G" as its icon). Click "Setup" on the right side of the
WinZip Self-Extractor converter.exe box. Another box will appear and
then disappear. The setup is complete, and CutePDF is ready for use.
CutePDF installs itself as a printer, and this allows any Windows
program to create a PDF.
Open any Windows application like Microsoft Word or Excel. Open any document you would like to convert to a PDF file.
Click File > Print. Select "CutePDF Writer" from the Name
List in the printer box. Click "Properties." Choose your "Layout" and
decided how you want your page to print. Click "Paper / Quality" and
"Color."
Click Advanced > Page Size. Click "Print Quality" and
change the DPI. The bigger the DPI, the larger the file size of the PDF
will be. If you are creating a PDF to be emailed, choose 72 DPI or 144
DPI. If you are printing this PDF, choose 300 or 600 DPI. If sending the
file to a commercial printer, choose 600 or 1,200 DPI. For most
applications, just adjust the DPI setting and leave the other settings
alone.
Click OK > OK > OK. A "Save As" box will appear. Enter a
filename for your PDF file and select the directory you would like to
save the file to. Click "Save." Your PDF is done.
Hi, Right Click the Mouse with your pointer on the screen Click on Properties You shall see a display window Click on Settings Screen Resolution... Slid to the Less Pixels Click Apply Button That should solve your problem Regards Salim
In short, no. The resolution on those LCD panels is extremely small and was originally designed for the small proprietary OS that came on them. Eventually Asus started putting XP on some of them, which was designed for 800x600 at the very least. As a result a lot of standard Windows dialog boxes are taller than the screen and make access to the buttons on the bottom difficult. One solution would be to use an OS that's designed for LCD screens with low resolution, like Ubuntu Netbook Remix. The only other solution is to upgrade to a netbook with a higher resolution screen, like most of the 8" netbooks.
And blue screen come on with white letters. It can caused by viruses, from unexpected shut downs and a lot of such kind of things, most of those cases operation system is demaged and may fix by reinstalling it, it you are familiar to bootable medias an a lot of tools you can scan your PC with sacndisc/chkdisk and problem may automatically disappear. Use F8 at startup and choose SAFE MODE to ensure that OP system is not "almost dead". Download any linux LIVE immage and boot from it, if PC is working LINUX wil turn on and no warnings will appear.
Install the cd of HP installation of your printer. If you have
installed the software thenQ 1. press the first button on the left of
your printer SCAN. The scanner will start and a message will arrear. Do
you want to scan another picture? 2. You Press the button DONE on your
screen it means NO. 3. HP Immage Zone program appears. 4. you must be
able now to see your scanned picture. 5 On your lest bottom of the
screen you will see TRANSFER IMAGES and the sign >> downway,
press and will appear 3 selections. FROM CAMERA, FROM SCANNER, TO
e-mail . 6 press TO e-mail and this is the answer. Now you can send by
e-mail what you have scanned!!
you need to reset the software with the printer and turn off your machine completely.
you already mass up the software with the printer. so you need to reset everything and make the printer works.
If still not working you can send it to me to fix it for you.
Go to your main desktop. Click on your background with the right mouse button then pick Personalize on the menu that pops up. The screen that pops up has Display Setting as an option at the bottom. If you click that it gives you screen where you can adjust the computer screen resolution. If you slide it to the left things will get bigger throughout the whole Operating system.
You may have to setup the EXTERNAL resoloution for a bigger picture than can generally display on the lappy's screen... there is uaually a setting for the dual display setup... Right Click desktop and click Properties, the video settings can be acessed from there... Also ensure ya have the latest most up-to-date drivers for ya lappy's Video too.
