YOU SHOULD ALWAYS HAVE A FOAM FILTER ON WET PICK UP-IF NOT YOU MAY EVENTUALLY BURN YOUR MOTOR UP SINCE THERE IS ALWAYS PARTICLES THAT WILL BE GOING INTO THE TANK ARE AND MAY GET SUCKED UP INTO THE MOTOR-THE REGULAR FILTER ON REGULAR DUST PICK UP
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
SOURCE: Vac won't turn on and the beater bar won't turn.
If you are having the same problem, then maybe there is something that you aren't doing right. But you do have a years warranty on what ever brand and model this is, take it in for warranty repair.
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
