HEY BROTHER THERE IS YOUR CODE.
*#7780#
AND SECURITY CODE IS 12345
*#06#
To check the IMEI.
*#0000#
To check the firmware version and date
*#92702689# *#war0anty#
To check the IMEI. The date when it was purchased
and the date when it was repaired.
*4720# (*hra0#)
To activates the Half Rate.
#4720# (#hra0#)
To deactivates Half Rate.
*#3370# (*efr0#)
To activates Enhanced Full Rate.
*#746085685# (*#sim0clock#)
To check the SIM clock status.
*#7220# (*#pca0#)
To activate the GPRS and Packet Common Control
Channel(PCCCH) supports.
*#7230# (*#pcd0#)
To deactivate the GPRS and Packet common control
channel (PCCCH)supports.
*#7760# (*#ssn0#)
To check the manufacturing serial number.
*#2820# (*#bta0#)
To check the Bluetooth MAC address
(Phone must have a built in bluetooth adapter).
*#7370925538# (*#res0wallet#)
Reset the mobile wallet.
NOKIA PHONE CODES :
Nokia Codes : *3370#
This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
Nokia Codes : #3370#
Deactivate Enhanced Full Rate Codec (EFR)
Nokia Codes : *#4720#
Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
With this Nokia code you can deactivate the Half Rate Codec
Nokia Codes : *#0000#
Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
Nokia Codes : *#9999#
Phones software version if *#0000# does not work
Nokia Codes : *#06#
For
checking the International Mobile Equipment Identity (IMEI Number)
Nokia Codes : #pw+1234567890+1#
Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+2#
Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+3#
Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+4#
SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : *#147#
This lets you know who called you last (Only vodofone)
Nokia Codes : *#1471#
Last call (Only vodofone)
Nokia Codes : *#21#
This phone code allows you to check the number that "All Calls" are diverted to
Nokia Codes : *#2640#
Displays phone security code in use
Nokia Codes : *#30#
Lets you see the private number
Nokia Codes : *#43#
Allows you to check the "Call Waiting" status of your cell phone.
Nokia Codes : *#61#
Allows you to check the number that "On No Reply" calls are diverted to
Nokia Codes : *#62#
Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
Nokia Codes : *#67#
Allows you to check the number that "On Busy Calls" are diverted to
Nokia Codes : *#67705646#
Phone code that removes operator logo on 3310 & 3330
Nokia Codes : *#73#
Reset phone timers and game scores
Nokia Codes : *#746025625#
Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
Nokia Codes : *#7760#
Manufactures code
Nokia Codes : *#7780#
Restore factory settings
Nokia Codes : *#8110#
Software version for the nokia 8110
Nokia Codes : *#92702689#
Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
Nokia Codes : *#94870345123456789#
IDRISH 911
