Question about Cell Phones
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased a new battery and original charger from sony and still have problem .
    Habit-Forming:
  • 92 Answers
This problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Posted on Oct 22, 2010
SOURCE:
Charging/Charged Indicators
I don't know what model of radio, but here is what I would try: pull the batteries and charge them on the charger by themselves if your charger allows this. The lights, well, some manufacturers just miss the boat. Especially on low end or "beginner" radios. I have one brand I can insert with NO BATTERY and the light comes on. Talk about useless. Charge times vary by size of battery and charger output, minimum is 3 hours, 12 hours much more likely but I see a lot at 5-7 hours. Hope this helps, model and brand helps always.
Dec 12, 2015 | Walkie Talkies Radio Communications
Why won't my zeepad 9xn charge? When I plug it in the indicater light flashes on the off quickly! I just to it not even a week ago
You must first charge your Zeepad for a minimum of 9 hours prior to using it for the first time. Though it may show that it is fully charged after 4 or 5, you must leave it on the charger. When you go to turn it on, you must hold the power button for at least 3 seconds.
Jan 03, 2015 | Tablets & eReaders
Bought a replacment battery for A30 and charging indicater does not show battery is charging
Im not sure what you are asking but I will try anyway.
You just want to see when you are charging?
Does the computer work when the charger is disconnected?
Most new batteries require hours to charge before they give any function.
How long will depend on the battery and charger. See the manual.
My battery took 2 days and I was angry. (24 hrs the manual said)
I put my wifes charger on and it began to function.
After that, my charger worked but not before...
Let it charge for 24 hours. Then see what happens.
Mar 16, 2010 | IBM ThinkPad A30 2652 Notebook
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Jun 26, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Charging Batteries
This could happen if the batteries have been recently used, and are "hot". Chargers use one, or a combination of, "end of charge" detectors. Either it's timed, detects a slight drop in voltage, or senses temperature. Try waiting 30 minutes to an hour after use before charging. Also, be sure the ambient temperature is within parameters. Too hot or cold (we live up north...gets cold in the garage) will affect the charger.
Sep 12, 2007 | Sony BCG34HE4 Tools and Hardware
Open Questions:
Cell Phones Logo
78 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
