Go to D-Link - TechSupport FAQ.
It means that the router is not configured yet. First, you have make sure that your internet wire is connected to the WAN port of your router and the computer should be connected to one of the LAN ports of your router.
Check the LEDs. Be sure that the LEDs for WAN and LAN where your computer is connected to is lit up or blinking (will depend on the brand and model number of the router).
Then you need to access the Web Utility of the router to set it up correctly. You need to refer to the manual of your router. Having a router does not mean that it will work immediately once you connect your internet or modem to it. It needs configuration.
You may also contact the tech support of your router (since the brand was not provided) for assistance
Thank you!
