Jeanie Rub Single Speed Massager Logo
Anonymous Posted on Oct 22, 2010
My Jeanie Rub machine is about 25 years old and has suddenly slowed and is straining so that I have quit using it until it can be repaired. I'm handy with machines and need to have an idea of how best to begin to take it apart, to clean and lubricate it. Any suggestions?
  • 1 more comment
  • Anonymous Oct 22, 2010
    I'd like to know if there is anybody out there who has actually tried to repair an old Jeanie Rub. The advice I received is good common sense, which confirms only my own approach, but not of particular value.
  • Anonymous Oct 25, 2010
    I just want advice from someone who has actually taken one of these old Jeanie Rub machines apart, on how best to accomplish just that. Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
740
Points
The new owner of the parent company of Morfam has an out of warentee program for under $90 buck they will replace the motor and pads and return it fixed. Core Products International, Inc. Acquires Morfam, IncComplete Service Package - $89.00 + $13.00 Shipping
- Cleaning
- Replace worn parts & pad
- Replace motor
http://www.coreproducts.com/jeanie-rub-warranty
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Oct 25, 2010
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
268909
Points
1659
It sounds like the motor brushes are wearing out. I am not sure you can replace the brushes in that motor. You may need to replace the motor.
The problem won't be taking the unit apart. The problem will be finding a suitable replacement motor. As the machine is 25 years old, you probably will not be able to get it from the manufacturer.
The commutators may be dirty. It is the part of the motor the brushes come in contact with. If you can get the motor out, you can use a pencil eraser to clean them.
The first step would be getting the unit open and see if there is any spec info on the motor to sear online to see if any motor manufacturers make a suitable replacement.
Colin Stickland
Level 3:
  • Master 22,516 Answers
  • Posted on Oct 22, 2010
Colin Stickland
Master
Level 3:
Answers
22516
Questions
Helped
6990032
Points
66324
Sounds like the motor windings have burnt out causing a high resistance which is resulting in no power ,dump it and buy a new one is probally the best alternative
Tom Carson
Level 3:
  • Master 3,083 Answers
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
683760
Points
8555
The chances are that some parts are worn, after all this time, or the motor is going bad, but you might get lucky. As far as taking the unit apart, you'll be hard pressed to find any directions. Best thing to do is just study the machine- everything that went together has a way to come apart, even if it has to be broken, which some things are designed to do, upon disassembly. However, most things can be taken apart with the right tools and patience. Look for screws or hidden fasteners under label plates and covers (some will snap off, as they are pressure fitted). Sometimes special tools are required or the fastener is impossible to take off without breaking something.
Sometimes it's best to get advice from someone who does this type of thing for a living- that is, a small engine repair shop. They could probably look at it and tell you what needs to be done, or at least what you need to do to get into it.
Anyway, good luck, study it well, and hopefully you'll be successful getting it fixed.
Jeanie Rub Variable Speed Massager. How to oil my genie rub massager.
Question edited for correct name of product.
No oiling, you just lube yourself.
Physio Supplies Canada https://www.physiosuppliescanada.ca > product > jeani...
All Jeanie Rub massagers are built in the USA to ANSI Standards and are CSA certified, ensuring they ... ***No periodic lubrication or servicing is required***.
2helpful
Morfam Jeanie Rub massager stop working
Jeanie Rub Service Information Jeanie Rub Warranty Information
Core Products provides a full one-year warranty on all defects in material and workmanship. Any misuse, unauthorized repairs, or product abuses are excluded.
Defective products reported within one year of date of purchase will be replaced or repaired. Call the Customer Service department at Core Products at 800-338-7014 for a return authorization number and to arrange shipping.
Out-of-Warranty Service
Core Products will repair most Jeanie Rub Massagers after the warranty has expired. Some of the very early models can not be repaired but can be returned for a $50.00 credit towards a new unit.
It is difficult to determine the extent of the repair until the unit is inspected however, we guarantee the service call will not exceed $89.00 plus shipping.
Basic Service Package - $49.00 + $13.00 Shipping
- Cleaning
- Cleaning
- Replace motor
Cord Replacement - $25.00 + $13.00 Shipping
- Replace worn cord
I have a jeanie rub and when it is running I get little peaces of hot medal that comes out. I need to know where to get repair parts to fix it.
1-800-338-7014
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
There is a 90-day warranty on any service that is performed by Core Products International.
Where to send it
RETURNS DEPARTMENT
1505 Parker Ave, PO Box 627
Chetek, WI 54728
If you have any questions regarding our service
information please call 800-338-7014.
1helpful
I need the carbon bushings for my morfam massager. Where can I get some, Please?
1-800-338-7014
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
Where to send it
RETURNS DEPARTMENT
Chetek, WI 54728
Top handle is broken, customer dropped it, can it be replaced? Where can I get the part?
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
Where to send it
RETURNS DEPARTMENT
Chetek, WI 54728
If you have any questions regarding our service information please call 800-338-7014.
I have a Jeanie Rub model # M69-315A. can i or is it pisible 4 me 2 replace the brushes inside the motor?
1-800-338-7014
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
Where to send it
RETURNS DEPARTMENT
Chetek, WI 54728
2answers
The cord on my massager is tearing. Can I get it
It kinda depends, You might be able to bring it to a store where they will repair it for a costly charge. If you are okay with working with your hands however, you can dismantle it yourself and just repair it yourself. How you would do that is, to take it apart screw by screw until you get the power supply out in the open and just wrap the wires that are torn with electrical tape and then just close it back up. MAKE SURE YOU UNPLUG THE UNIT IF WORKING ON IT
1helpful
3answers
Jeanie rub massager
1-800-338-7014
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
Where to send it
RETURNS DEPARTMENT
Chetek, WI 54728
If you have any questions regarding our service,
please call 1-800-338-7014.
Top Jeanie Rub Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Jeanie Rub Health and Beauty Expert? Answer questions, earn points and help others
