Question about Stanley Fatmax Xtreme Retractable Utility Knife
How do I put the first blade in the new knife?
    New Friend:
    Problem Solver:
  • 19 Answers
Open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Posted on Oct 22, 2010
6ya staff
SOURCE:
How does an electric knife work?
The way the knife works is that it has two knife blades put together. These blades are serrated (notched). When the power is on, the blades move sideways and basically saw through whatever they are cutting.
Jan 14, 2013 | Home
Tip
How to choose the right knife for your camping trip
depending on what your plans are for the uses of your knife you will first want to pick either a folding knife which are smaller and can be put in your pocket easy to carry then you have nonfolding knifes that have sheifs which need to be on a belt or put in a backpack pocket there bigger then a folding knife and thicker blade then a folding knife a non folding knife are mostly more stable then folding knives you dont have to worry about the blade folding down on you fingers but most folding knifes have a blade lock just remember when choosing your knife make sure its comfortable to use and not to big bigger is not always better and dont forget a good sharping stone when camping your knife is your life
on Jul 24, 2012 | Camping, Backpacking & Hiking
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Apr 21, 2011 | Stanley Utility Knife
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Stanley Fatmax Xtreme Retractable Utility Knife Logo
249 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
