Question about HP Photosmart C7250 All-In-One Thermal Printer
HP C7250 Says two colors need replacing so it wont print. Black is all I need for now, so why wont it just print using the black ink cartridge which is fine? How do I fix this....
  • HP Master
  • 7,733 Answers
Using the HP Print Diagnostic Utility in WindowsUse the HP Print Diagnostic Utility to help you identify and fix common problems when printing.
Posted on Oct 22, 2010
SOURCE:
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have an hp deskjet 940c. the colored ink is out but there is plenty of black ink however the ink light is flashing and it wont print. do I need to replace the colored ink in order to print something or...
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to
BW and not color in the configuration menu. That should permit you to print in BW only.
Mar 22, 2011 | HP DeskJet 940c InkJet Printer
Printer wont print it has a new black ink cartridge but the color inks has no more.how can i print black only.
You cannot print unless both cartridges are installed and have a decent supply of ink left in them. It doesn't matter if your printing only black and wont need to use the color cartridge. It still have to be installed with ink for your printer to work. There is no way of getting around this problem.
I wish I had better news for you.
Nov 10, 2010 | HP Photosmart C7250 All-In-One Thermal...
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Can you refill the black ink cartridge on the c7250? If so, how.
Thermal printer? Normally a thermal printer doesn't have cartridges.
Anyway, my opinion is you should not refill ink cartridges. I have a basement full of printers with dead print heads due to third party ink being used or third party cartridges being used in a wide assortment of printers including a HP Photosmart.
Don't run the risk to save a couple bucks, please.
Thanks for you interest in FixYa.com
Jan 27, 2010 | HP Photosmart C7250 All-In-One Thermal...
Had black ink cartridge filled, but now the
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | HP Photosmart C7250 All-In-One Thermal...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
238 people viewed this question
Clive
Clive
Thomas F. Schneider
