Moen 1 Handle Lever Shower Faucet With POSI Valve NI Logo
Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No hot water great water pressure,no leaks,when turned all the way to right pressure becomes dribble, moen Adler
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Oct 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
34135
Points
103
The shower cartridge needs to be replaced.
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
2helpful
2answers
Turn cartridge to open ccw,, put it in , do up nut,put extension on, turn on water and just a dribble comes out, handle will shut off dribble. aerator clean as hot side works fine
You must have something in there gumming up works. Is the water on? Does the shut off work good? Is the cartridge in right? Are you sure it is the right cartridge? Can you see any gunk in the cartridge? Make sure the hole lines up when you turn it ccw, make a note of the position then turn it on, make another note, then take it out and check your positions with the holes. See if they line up. Check it out.
2helpful
2answers
I installed a Moen Adler faucet. It will not shut
You may just have a piece of sediment lodged in the cartridge from when the water was shut off during installation. Carefully remove the cartridge and turn the water on to flush out any obstructions. re install the cartridge and test.
Installed new beautiful 4 piece arch neck faucet a month ago. Have had pressure problem ever since. Hot water actually dribbles after about 3 minutes. Already tried everything suggested here. Was going to...
My husband is a plumber. He COMPLETELY agrees with u that u should get something else- of better quality. He says u get what u pay for! Price Pfister is not of the best quality! He recommends anything MOEN. They're great and rarely have problems! Good luck!
1helpful
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
