Dell Vostro 1510 Motherboard System Board - J475C Logo
Posted on Oct 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My window media player dosent play mp3 discs - Dell Vostro 1510 Motherboard System Board - J475C
  • 8 more comments
  • starstern Oct 22, 2010
    I FIND NO FILE TYPE TAB
  • starstern Oct 25, 2010
    was told to go to tools options file type choose mp3 in order to get windows media player play mp3 ,but find no link for file type in that box ?
  • starstern Oct 28, 2010
    wright
    am routinly playing cd's on it ,it also plays downloaded mp3
    just mp3 disc it dosent recognise
  • starstern Oct 29, 2010
    checked for updates ,came back ,yours already updated upmost
    upgrade ? how is this done ?
    vostro 1510 dell laptop
  • starstern Oct 31, 2010
    yes you are wonderfull informative ,you got it play mp3 disc !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!congratulation;
    before im losing you ,may i try another solution which failed by other reps
    my system have the feature restore to last sesion ,so when come the next day it opens me the same way as i had left it the deay before with all tabs e.t.c.but it happen then and now that it didnt restore it for some reason ?thinking maybee it went thru a reboot so toughourly,is there any program that can assure me to have always restore my full last screen ?
  • starstern Nov 01, 2010
    Download both these drivers and install. The reboot. Click on the links
    Chipset
    Audio
    Reply
    finnaly after so many other advises from other advisers wasent helpfull ,i got it play mp3
    i did it ,time will tell if worked ,if it did then how do i accept it ?
    now i checked my older disscousens with fixya with no realy resolve ,find just one more to ask ,how do ask it if want direct it to you ,by this box or to go back to need additional assistence ,and will be able to choose you ?
    i have dell vostro 1510 , 1.80 ghz processer, 2037 mb ram,hard drive 160 gb ,whenever many tabs are open ,or downloading or open site with much graphic ,my system tend to freeze for a little while ,been told about programs desinged to make use of little ram for much more memory by directing the available memory to only active usage and other parts to be like in sleep mode so to say ,but my expirience with them ,that they by them self use up tremendus memory ,so what you gain you immidiate use it up .is there anything better ,and also as results help speed up the computer as well alltough go with dsl and not fios or high upgrade dsl or cable ,???
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Oct 25, 2010
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512255
Points
14106
Ok. Sounds familiar. What is the error message?Audio device not found?
  • 5 more comments
  • Anonymous Oct 28, 2010
    That means your sound card driver is not installed. Can you confirm whether the motherboard model no you have posted is correct?
    Have you tried upgrading the player? May be that would resolve the issue.
  • Anonymous Oct 29, 2010
    Ok. So its not a player issue. Ok lets try re-installing the chipset drivers. May be some audio codecs are corrupted. Please get me the make and model of your motherboard.
    Chipset
    Audio
  • Anonymous Oct 31, 2010
    Star tern. Please address who you are referring to here.
  • Anonymous Nov 01, 2010
    Cool. So it was me huh. Can you please accept my solution then so that I will get the credit for it?
    Thanks,
    Sai.
    Thank your for the accept. As for the full screen problem, you should just install the video driver to ensure that it does not happen again
    http://support.dell.com/support/download...
Anonymous
Level 3:
President:
  • Master 1,194 Answers
  • Posted on Oct 22, 2010
Anonymous
Master
Level 3:
President:
Answers
1194
Questions
Helped
307594
Points
3666
Proceed as under:-
  • Click START---Click All Programs---Select Window Media Player---Select TOOL (find this on the Top left corner of media player screen)--- click OPTIONS---click FILE TYPE TAB----Mark MP3 Audio file----click APPLY & then OK. Restart your computer, Now MP3 should play.
Thanks...!!
Catalin Turcu
Level 3:
  • Dell Master 4,924 Answers
  • Posted on Oct 23, 2010
Catalin Turcu
Dell Master
Level 3:
Answers
4924
Questions
0
Helped
1231323
Points
13383
It is probably damaged or something like that ..cause windows media player is made from the start to play Wma and Mp3 files...In this case you have to try to reinstall the next update ...or repair the installation that it is on ...
try from this location ...and let me know what it says..It may be just a setting or so ...or another player is set to cover the file association with the mp3 files..and in this case the WMp does not starts right the way when double clicking a MP3 file..
If this is the case ..just click right on the file..(mp3 one) ..and properties..and change...and in there choose windows media player to be the associated program ...and after that apply and ok ..
Here is a location from where you can download and install the windows media player again ..It may ask for windows genuine advantage to be verified ..
http://www.microsoft.com/downloads/en/details.aspx?familyId=b446ae53-3759-40cf-80d5-cde4bbe07999&hash=HWu84YXYOpYY93nvQ5s%2bOPrGC3X7eSVa%2fyY4GmL8TavJloYbw%2f0QiDbNks3tujVSfdTOguyng19dT0cvCJk%2fUg%3d%3d
Just click continue...and get the validation after the wga software is verifying the operation system ..and download and install the windows media player again ...This will fix any error that it may have ..
2helpful
I am trying to download music I purchased on itunes to my mp3 player. It shows it on the list when I have it on the computer, but does not show or play on the actual mp3 player. What do I do>
Hi dasdis07...
You did not say what manufacture your MP3 player is so it is hard to tell you what to do.
I will assume you have a normal MP3 player...not an Ipod.
Check to see what format your MP3 player will play...because the I-tunes songs are in ACC.
Normal everyday players play MP3,WMA,ect...but will not play ACC that plays on ipods.
You will also need to download (FREE) and run a media converter so that you can convert your ACC music files to MP3,WMA,etc files that will play on your MP3 player.
Once you have your music converter and on Windows Media Player, then you can transfer them to your MP3 player
What your going to have to do is follow these instructions below:
Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Webpage where you can download a FREE media converter: http://formatoz.com/
Please take time to rate me
How to down load music on mp3
You should of got a disc with your mp3. You need to download that. Then plug it in through USB onto your comp/laptop. Then download a song you like on your computer. I use limewire to download music. Then simply play all the music on windows media player. I do them all at once (not so there all playing just so one plays then the other does and so on just like a album but on media player) then if it doesn't recognise your mp3 click "sync" then click "now playing" then "sync all"
Hope I helped Dr Reed
Songs I have downloaded to my sansa e250 mp3 player won't play
This is a simple formatting problem, To fix itSOLUTION 1:well there isnt really a way, other than instead of using windows media player directly, you can copy it out of the disc folder (in my computer) and into your my music folder and then import it from your my music folderSOLUTION 2:You can download itunes for free, upload discs to your itunes and then make a new disc (make sure it is in mp3 format<you will see what i mean>) and the rip the disc like you normally do Hope i helped If this doesnt work the email me at [email protected]
My i pod video plays then dosent
Check that the songs you have uploaded onto your IPod are AAC files. Otherwise the iPod will not play them. Also clean the wheel if its grubby or in a case as sometimes this will not allow songs to be played.
I have a mp3 player is a emerson mp513-4
There's a cd that comes in the package, put it into your computer and look at the guide on thier. If this doesnt work contact me, or professional help!
2answers
2helpful
File format not supported
use the media converter from philips this: Media Converter for Philips
Mp3 problems
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
4answers
Problem playing music files with new Goodmans mp3 player (GMP34G5)
i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
