SOURCE: hp pavillion dv9000 won't boot. tries to start,
Check the memory! Try rplacing with like memory first!
There is a Limited Enhancement Program that includes this model. If you are in the US call 1-800-474-6836. If you are outside US check the HP.com website and search for the Limited warranty enhancement Program.
This is normally a video chipset issue that is embedded in your MB. If your notebook is part of the program, hp will shoulder the repair cost for the MB replacement.
Please vote, Thanks!
SOURCE: HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
SOURCE: Display driver error for HP pavilion dv9000.The
These laptops have severe issues with the graphics card and drivers (i have the same series). check to see if your model is on the recall list by hp first.
SOURCE: Can't get wireless adaptor blue light to turn on.
if its still under warranty get in touch with HP they have had hardware issues with this
there are things you can try
START>All Programs>accessories
right click command prompt and left click run as administrator
In window that opens enter at command prompt sfc/scannow
this will scan all your windows OS and replace any corrupt files/ registry Entry
you can go to device manager and uninstall the drivers
the issue or problem is that the driver simply dissapears (which says to me hardware fault)
there is a trick to remove old drivers on vista that naturally you wont see
click Start>
RIGHT Click computer> select PROPERTIES>click ADVANCE (tab)
you will see ENVIROMENT VARIABLES (button) click this
system variables box click NEW button
box should appear
type in NAME BOX
devmgr_show_nonpresent_devices
type in VALUE BOX
CLICK OK
right click computer select manage>device manager
click VIEW show hidden devices
to remove right click specific device select uninstall
hope some or any of this helps, if i can help further i will
try hp also and if all fails could be a dongle, i still say its a hardware
fault and HP should do a recall.
