The feed dog & the presser foot have to work together to feed the fabric thru the machine
The feed dog should be seen when you look at the needle plate, if not the feed dog setting should be checked--the feed dog lever may be to the right of the bobbin area
Open the light bulb door also called the Lamp Cover door or Face Plate,, there should be a knob at the top round or star shaped,, that adjusts the needle bar that puts pressure on the presser foot,, it may have numbers or letters, mine is a star shape & has numbers on it & is set between the 2-3
Adjust it a little at a time & then sew to see which setting is best for your machine
