Durabrand phone PH559 suddenly does not show my stored incoming
calls. The Caller ID screen is blank. I have to pick up the receiver in
order to see them, but they disappear as soon as I put the receiver
down.
Also, incoming calls no longer light up the flashing red light, plus I
have to answer the phone without knowing who is calling.
Sir, please cancel my request and remove any charges to my Mastercard account. Thank you very much for trying, but it's hopeless. The Customer Support number given in the Durabrand manual does not work. Neither do the manual's directions for resetting the Caller ID screen, or even changing the batteries. I tried all that SEVERAL times with no success. I give up. Thanks again for trying.Sir, please cancel my request and remove any charges to my Mastercard account. Thank you
You can't post conmments that contain an email address.
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
pls go to menu then contacts or phone book and select the option showmy caller id. this should help u in getting tyhe3 name or the number of the person calling you
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
the directory key is storage for caller id. dtr80 is not the type of system but the type of phone. The system needs to have other components like a mif card in order to store caller id. Also if your phone does not ring with incoming outside call than you will not get caller id.
What IS the solution?
