Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY! Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
