The CMOS battery is the RTC battery. Real Time Clock.
It's smaller version of the CR2032 batteries you're used to seeing in a desktop computer.
It's in a plastic holder that resembles a bag. The plastic 'bag' wraps around the battery.
There are two wires attached to the battery, and come out of the 'bag'.
One wire connects to the Positive pole of the battery, and the other wire connects to the Negative pole.
The wires are soldered to the Battery.
At the end of the wires opposite of the Battery is a small white connector. It's a Male connector.
The Male connector plugs into a Female connector on the motherboard.
Once you have the RTC battery pack removed, and the battery itself removed out of the 'bag', you can match up a new battery to it. Carefully make a **** in the side of the bag, and remove the battery/wire combo.
Have a competent repair person remove the wires, and connector to the old battery, and solder the wires/connector to the new battery.
Install the battery/wires/connector combo back in the 'bag', use glue to seal the 'bag' once more.
(Or you can use silicone)
The RTC Battery is on the BOTTOM of the motherboard. This means the laptop has to be completely disassembled in order to access the RTC Battery.
In the above heading it states Acer TravelMate 4000 PC Notebook. This is the TravelMate 4000 series.
There are many models in that 4000 series.
The Model Number is on the bottom of the laptop.
Models in the 4000 series are; 4000, 4010, 4020, 4050, 4060, 4070, 4080, 4100, 4150, 4200, 4210, 4220, 4230, 4260, 4280, 4320, 4330, 4330G, 4400, 4500, 4520, 4530, 4600, 4650, 4670, 4720, 4730, and 4730G.
The above Model list may not be complete.
The disassembly guide for the Acer TravelMate 4000 series will cover all of the above models.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Scroll down with your eyes to the Travelmate heading.
Go down to the third line that starts with 2700, read across to 4000.
Click on 4000.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
However if you do not have the latest Adobe Reader, I would suggest downloading it.
(Adobe Reader 9.3.4)
After you click on 4000 nothing will happen for up to 30 seconds. (Maybe more)
The screen will be blank. The file is downloading in the background, and after it has fully downloaded, the first page will pop up.
For additional questions please post in a Comment.
Would appreciate it if you would rate my solution.
Regards,
joecoolvette
In the Service Manual - downloadable from here...
http://rapidshare.com/#!download'50'108908740'Acer_TravelMate_2300-4000-4500_Series.rar'3103
Chapter 1 page 5 (item 10) - RTC battery connector -
That's real time clock (CMOS) battery
click the Address above to go to the website and download the service manual
Hope that was helpful,
Brian/Sammyone
