What's the model number and what's the part you need? If you're not sure what the part's called, check here:
https://www.manualslib.com/manual/733139/Cajun-Injector-Electric-Smoker.html?page=4
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
I had the same problem. Readout showed 330 degrees, but it should have been 60. Saw all the bad reviews on this product after I started to research this problem, so I figured I would try to fix it. I drilled all the rivots out of the back panel. There are 2 thermocouples, 1 for the meat probe and 1 for measuring the temp inside the smoker. Both thermocouples have connectors in about the center of the smoker. I cut the wire on both sides of this thermocouple and spliced them together without the connector. Works fine now.
