Apple iPod MA446LL/A MP3 Player Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went blank. the music is working fine and i can play songs and stuff.even the backlight is working. i've tried restorin it usin itunes and other soft wares  aswellbut without luck.the music always plays but i can't see anything on the screen exept a blank white image.Please help!! My iPod nano is playing music, but the screen is white. Everyonce in a while the regular screen will show up, but then after I turn it off, it's blank again when I turn it on. I dont know how to fix it!!! Help, please!! my ipod 60 gb it has a blank white screen and i cant fix it cant even hear my music what can i do?
Anonymous
Level 2:
  • Apple Expert 108 Answers
  • Posted on Sep 25, 2008
Anonymous
Apple Expert
Level 2:
Answers
108
Questions
0
Helped
140901
Points
144
Sounds like you may need a ipod diagnostic test to test your screen.
Try:
http://www.ipodrefresh.com
Ekse
Level 3:
  • Apple Master 13,435 Answers
  • Posted on Jun 05, 2008
Ekse
Apple Master
Level 3:
Answers
13435
Questions
82
Helped
3985285
Points
38023
2 Related Answers
Anonymous
  • Posted on Jul 07, 2008
SOURCE: my iPod nano 2gb silver is showing a blank white screen.
my ipods screen went white and still played music. in frustration after trying all the restore reset and all the other suggestions i found on the web i finally opened it up and found a loose connection that i pluged back in and now it works fine. not for the faint at heart. but it wouldn't work so what the .......
A
Anonymous
  • Posted on Oct 20, 2008
just plug it to your computer and restore it on itunes. that should fix it
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Ipod nano 2gb screen locked
You can follow this link it will give the details of ipod screen lock http://support.apple.com/kb/HT1350
My ipod has a blank white screen how do i fix it
if your ipod is within a year of purchase it's still under warranty. return it to apple and they will replace it.
or if it is within 30 days return it to the retailer and take your receipt and they may just give you a new one.
It sounds like the LCD went bad, it happens and apple is aware of these issues so try and get it replaced.
If you don't want to do the warranty thing, go onto ebay and buy a screen for it and do a search on youtube for a "take apart" video for your model.
Good luck
I have an Apple Nano 2GB black classic (silver back and sides with black front and square edges). The screen just started partially blanking out - not black but no image through the lower 2/3rds of the...
Well if the screen is not cracked and there is no black on the screen when the ipod is off then the pixels in the screen died. Easily solved, buy a new screen on ebay, I had to replace my ipod nano screen(clasic) because it was cracked, so this should work for you.
1helpful
My iPod's screen is white
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
1helpful
Nano goes blank
Reboot your Ipod by holding down on the center button while holding down on the menu button.
This should reboot your IPod.
If that doesn't work plug your Ipod into Itunes and restore your software back to factory settings. Make sure that battery if fully charged as well.
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Try the Five R's suggested by your user's manual - you can get the manual from Apple's website if you have lost it:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
2helpful
3answers
Go throught this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
Video
Greetings,
There is no way to update your old Nano to play video. There is no video processing chip, and the screen is not of a high enough resolution. My second generation ipod with a black and white screen also shows the option for music videos, its just due to the iTunes software.
Take Care
-WN
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
