My Imageclass D320 will not feed paper through the printer. No matter what paper I put in it, I get an alarm and the "supply rec. paper" message.
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Try making sure the copier is on a even table top.. How old is it??? You may need a paper feed cluthch and paper pick up rollers. You may also have a piece of paper jamed in the paper present sensor. Have you tried the manual feed tray?? You may have to call a service tech...
What a **** is going on with this ******* printer why do i have to download this ******* program dicactor to install my ******* drivers for my ******* printer please i jsut want my drivers for my ******* image class D320 where to find this ******* drivers
I'm getting the same error message! Help!
I have similar problem. I also replaced roller and pad. Paper is picked up from tray then it travels approx. half inch then I get Rec Paper Jam message. At this point paper is between roller and pad.
Any suggestion will be greatly appreciated.
The copier still copies so I imagine there's nothing wrong with the rollers or clutch or anything mechanical. I am only left to believe it must be something to do with the driver. I have D320 the driver I'm given is like a generic d300 series. I can only do some more research to find out what more can be the problem.
My Canon Imageclass D320 has letter sized paper inserted inside its tray, but the printer thinks it is a legal sized paper. I checked for paper jams by the sensor but there are none. What should I do??
our copier will not feed paper too. it gives the 'supply rec paper' alarm...what do we do?
