GPS Logo
Posted on Oct 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know the international colour codes for wiring a three pin plug please
Anonymous
Level 3:
  • Master 1,514 Answers
  • Posted on Oct 21, 2010
Anonymous
Master
Level 3:
Answers
1514
Questions
Helped
331942
Points
3516
The colours vary from country to country.
In the UK and Ireland the colours are
Brown = Live, (Goes to the pin connected to the fuse, on the right if the longer, earth, pin uppermost)
Blue = Neutral (Goes to the pin on left if longer, earth, pin is uppermost)
Green and Yellow = Earth (Goes to the longer pin)
In the USA and Canada
Black = Hot (Goes to the pin on right when the long round,earth, pin is nearest the floor)
White = Return and (Goes to the pin on Left when the round, earth, pin is nearest the floor)
Green = Earth (Goes to the longer round pin)
How do know what side is hot or negative on power cord
If it plugs into the mains there is no negative wire, it is Live or Line or Hot and the other power cwire is Neutral or Return.
All heaters should have a three pin mains cable to allow for a safety Earth or Ground wire.
If we had a clue as to your location, we may be able to help further, as colour codes vary from country to country.
Colour code wiring diagram
Pin 1 - Signal (Green/Yellow) Pin 2 - Signal Return (Grey/Red) Pin 3 - Signal (Orange/Red) Pin 4 - +5V Reference (Orange/Yellow) Pin 5 - Ground (Black) Pin 6 - Not Used
Does pin placement in 4 pin plug 3 wire stator matter for a 05 HD softail deluxe?
You should have a three pin plug for a three wire stator. What in fact do you have??? AND no, the pin placement does not matter in a three wire AC alternator system but the wires come assembled to pins in a plug so I do not know how you would have them changed anyway OR have four wires.
1helpful
Wire colour code
Trying to put a flat 7 pin plug for a trailor in my car camry sv21
Use a multimeter, and test each wire individually as you turn on/off lights. You won't need a colour code with this method.
1helpful
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
1helpful
1990 mitsubishi gto radio wiring
i have just put one in mine!
the only way you can do it if the plugs are not on, will
be to colour code the wires to pins. if you need the colour to pin codes
let me know.
All the best.
3helpful
2answers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
