Radio may have been wired improperly or fuse may have blown. First check fuses. Below is the color scheme for your radio wiring. The dimmer wire is White with a green stripe. This wire should be connected to the orange wire of your aftermarket stereo. If you have an unusual stereo, leave the factory wire unhooked (and insulated) until you can verify which wire on your stereo is for the light. Let me knoiw if you have questions.
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2?
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6? x 9?
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
