Harley Davidson 426290 AM/FM Radio Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 harley davidson am-fm cassette radio
The battery on my electra-glide went dead this winter, from sitting. Jumped with a charger, at 40 amps.Now every function on the radio is working, but no sound comes out of the speakers, except for a low static sound. Is this a small repair bill or should I find a new radio? I am experiencing exactly the same problem. Battery went bad over the winter. Jumped it at 40 amps and get the speakers to hum but no radio. I replaced the battery, as it was bad, but still the hum and no sound. Any ideas? DE in Iowa
Benjamin Patri
Level 3:
  • Master 3,037 Answers
  • Posted on Jun 05, 2008
Benjamin Patri
Master
Level 3:
Answers
3037
Questions
7
Helped
707148
Points
8239
First I would try driving it a few times to see if the battery will charge completely up and the problem will go away, if it doesn't, then you may just have something fried from starting it. You may also try hooking a different battery to it. If anything, take it to an electronics store and have them check it over if none of the above work and they will be able to narrow it down well enough for you. I know that this has happened on multiple bikes so I will see if I can see anything else that might have fixed this problem. Let me know if you have any other questions
  • Benjamin Patri
    Benjamin Patri Jun 05, 2008
    It seems that the high amps fried the radio most likely or if you are lucky just one internal component. Look for a blown capacitor to start with and see what you find. Next time I recommend a low slow charge instead of jumping the bike. If a capacitor is blown, this will be pretty cheap, so take a look.
    When charging, you should charge at 8-10 amps and the volts are what you need to start the bike.
    Let me know of any further questions that you may have
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
Anonymous
Level 3:
Genius:
  • Master 1,142 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1142
Questions
6
Helped
444599
Points
3128
Did you try doing a hard reset to the device
  • Anonymous Jun 05, 2008
    Its a very simple issue all you need to do is that open the set and replace the battery with a rechargeable capability, it will be resolved,.
    Regards
    Maanita
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563568
Points
4850
This is not the battery problem sir
    this is due to some fault of inner components that u need to replace. it wont cost u more sir
1 Related Answer
ironcrossaud
Iron Cross Audio
  • 281 Answers
  • Posted on Sep 04, 2009
SOURCE: 2002 harley davidson am-fm cassette radio
check out www.radiosound.com
2002 FLTR Radio Problem
You fried the circuitry in the radio, you can't jump the battery at so many amps, it needs to be gradually charged up if the radio is attached. You need to take the radio to an electronics store to see if they can salvage it and replace the fried board, if they can't, then you need a new radio. This is a common problem that many people have experienced so don't feel bad since you aren't the first to do it.
I'm sorry that I am the bearer of bad news, but if you have any further questions, please let me know
What are the factory stereo specs for a 2007 electra glide classic?
Radio is a 4 channel 22 watts per channel 2 ohm stable unit. There are no pre-amp outputs, so be sure whatever amp you're using accepts high level inputs, or have pre-amps installed by Iron Cross Audio. When adding the amp, be sure the speakers used are impedance matched to the amp, not the radio.
Radio turns on but no sound from the speakers?
The jump should not have affected your radio, other than to blow the fuse. As it did not do that your problem is something else. I suggest either a radio buff or an Auto-electrician, once it gets beyond basic wiring it is out of my league. The only way you will know, is to take it apart, but to find the buggered part has always beaten me. Use a multi-meter and you should get lucky. Good Luck.
Sounds like you may have blown one of the radio fuses. Don't know about that radio but usually there is one fuse red wire for the key hot and one fuse for the radio memory yellow wire and one of em is blown. I don't know if there are security codes for those radios or not if both of the fuses are good. Dont know if it will be a main radio fuse just in the main fusebox or block or if there is another or other fused in the fairing.
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
