When I try to power up my laptop using the AC power cord, everything initially appears to be powered up (all LED's light up, cooling fan starts) but almost immediately (half a second) it shuts down. The only thing still lit is the orange battery LED indicating it is charging. I've tested the voltage output of the power cord and it is within tolerance (~12 volts). When I attempt to power up my laptop solely using the battery (no AC cord), nothing at all happens (battery appears dead). My laptop is a couple years old. Shouldn't my laptop be able to power up using the AC power cord even if the battery is discharged or needing replacement?
Yes it should work even without a battery, sound like a hardware problem possibly in the motherboard.
I constantly use my laptop without a battery.
well its most likely a hardware failure.. Theres not much we can do about this.. possibly would need to replace the motherboard.
You may press the accept button on my solution if you are satisfyed - if you have any other questions I'l gladly answer them.
Try booting under AC power with the battery removed.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
You may have a bad DC connector:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Problem symptoms:
It is stone dead when I try to boot it without a battery using only the AC power cord. No flicker of any lights or cooling fan. Bummer!
