Whirlpool GU2400XTP Built-in Dishwasher Logo
Posted on Oct 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drain is plugged, leaking water - Whirlpool GU2400XTP Built-in Dishwasher
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Oct 20, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232574
Points
12714
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
2answers
1helpful
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Water leaking under dash on the passengers side of 2000 xterra
Only 2 things this can be. The air conditioner drain is plugged, or the heater core is leaking. If the water smells loke antifreeze then the heater core is leaking and needs replaced, if no smell then the AC drain is plugged. You can acces this from und3er the vehichle, should be a small tube near the firewall to drain outside the cab, just runn a wire up in it and see if something comes out like moldy water!
Leaking water. The hose is draining correctly. Not plugged up
you may either have a leaking drain hose or bad water pump. these washers are famous for drain pumps leaking. this is caused by using to much soap. 2 tablespoons per load.
1helpful
Water is leaking inside
Clogged drain plug. the plug is located in the back of the freezer. Empty the freezer out and pour VERY hot water down the drain hole slowly this will unclog the drain and will stop water from leaking inside your fridge.
Gasket were replaced but still leaks water
If leaking out front of door on freezer, then you have a drain plug that is stopped up or frozen. Drain plug is located in freezer, underneath evap coil, when unit goes into defrost mode, if drain is plugged up, water has no where to go except out thru doors.
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Where is the water drain plug for a 2006 hyundai sonata?
Does this vehicle have a Sun/Moon Roof? The 'water pan' as you call it, is not equipped with a 'plug.' It's part of the Sun/Moon roof assy. the problem is most likely the drain tube (perhaps misrouted) from the roof to the outside of the vehicle (drain alley). The drain tubs are located behind the head-liner at 4 corners of the assy. Otherwise, the leak you describe is possibly being caused by a windshield leak.
Two small holes in the bottome of radiator; it's leaking water.
THE OTHER HOLE is actually the drain hole when you open plug it comes out that hole. you should be able to get a new plug at any parts store
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
