You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. if this fails then its hardware problem you need to service tv .....
The television could have failed for any number of reasons.
The pixelsdon't all suddenly fail when they wear out. Instead, you see a gradualdeterioration of the image, as enough individual pixels fail to affectthe appearance. Colour shifts are also experienced.
Your failure is more likely to have been caused by a problem in the power supply to the plasma screen. When there is a total failure of that nature, it usually means theproblem lies in some part of the uit that supplies power to thesubassembly or controls it in some fashion. A picture tube could loose its seal, causing a total failure, but a plasma screen hasa seal for each plasma element. This makes a total failure unlikely,unless the entire screen has come apart.
It can be repaired.
If you are still under the warranty period, you are lucky.
Contact Haeir service centre.
www.haier.com/index.htm
Hope my info solves your problem,
Thanx for using fixya,
Cheers
Did this occur suddenly, or was the picture gradually failing over time?
