PRINTER SCREEN READS. INK SYSTEM HAS FAILED. UNABLE TO COPY, RECEIVE FAXES,OR PRINT. REFER OF PRINTER DOCUMENTATION. ERROR 0xc18a0201 TURN POWER OFF , THEN ON AGAIN.
I DID THAT SEVERAL TIMES. WHEN POWER COMES BACK ON PRINTER MAKES NOISES THEN SCREEN READS SAME MESSAGE.
The first problem is you have an ink jet consumer printer. Go to their support site and search that error code. That may help, but don't count on it. HP is notorious for selling defective products and have lost more than one class action suites. you can try these steps http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
But it could also be the error for when the ink resovors are full in the bottom of the machine. It will stop working by design then. If it were to over flow you would see where all that ink went you been buying, so they stop the machine before that happens. Best advice is take it to the nearest dumpster and deposit it inside it, and buy a laser printer. It was the best thing I ever did.
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
if you are a tech and have opened one of these before, clean the service station on the right side, oil the carrage rod. time about 1.0 to 1.5 hours. most of the time this is the problem on inkjets.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
