You need to change the software of your printer by going to TECH mode and sending some files to the printer.Give me you email so i can send you the instructions and the software if you want to.
visit www.nakshatraworld.com
Why visit www.nakshatraworld.com ?!?! you want money for helping people and I am doing it for free ! There is no point of people visiting you.
i changed my soft ware fut i am getting scanner error my printer version is 1.21 please help me out
babu
Did you disassembled the printer for some reason ? 1.If yes check again that all cables are connected.2 Is the scanner moving at all when you turn on the printer?Is there a strange noise comming from the scanner like gears dont mesh up properly?
my email id :[email protected] get the message as toner exhausted replace toner,.i m using samsung scx4300.thanks
I have sent you the software and the instructions.
i have samsung laserjet 4300 ....having error change toner .....plz send the error fix instruction to my [email protected]
i got yout file.thanks.but i am not getting tech mode even after following your instructions.can you tell me how to go to tech mode.
Probably you are missing some step of the procedure :
1) Connect PC and printer with USB cable.
2) Turn on the power of printer.Wait for (Ready Status - Toner exhausted)
3)Then go in TECH MODE after pressing sequence:
Hi.I fixed the problem.thanks a lot for your help.you are doing a gr8 [email protected].
@haivanko I do hav the same problem plz send me the required software and instructions
if you can,
my email id is [email protected]
Sir,
You are doing great Job- Doing free service for people.Really you are great.
I have printer SCX4300.I follow as per -http://www.youtube.com/user/TranHuuDung1... .
But still my printer says 'toner exhausted' is it possible to clear this prob?could you help me?
Plz send by email - [email protected]
Thanking you in advance .
Rgds
Anbu
[email protected] Hi I'm having the same problems and would like the software sent to me as well. I'm not computer saavy so if you could please send instructions that are easy to follow it will be greatly appreciated! Thank you so much!!!
samsung 4300 printer displays toner exhausted message and does not print, can i change the software of printer by going to TECH mode my email id is [email protected], pls send me software and instruction
hi haivanco i to have a same problem
my email id is [email protected] my printer shows tonner exhausted repalce tonner
my email id is [email protected] my printer shows tonner exhausted repalce tonner, thanks
my email id is [email protected] & need solution to fix the toner exhausted error on printer SCX-4300. Kindly help.
Dear Haivanko, could you be so kind to send me the instruction and siftware too. My e-mail is [email protected]
Dear help me, my printer shows replace toner - toner exhausted how can i fix the problem my email is [email protected] - printer is scx-4300
[email protected] thc!!! :)
I have the same problem please send me the solution at [email protected]
i have also the toner exhausted replace toner problem in samsung scx 4300 so please send me the solution at " [email protected]"
[email protected] please send
Email: [email protected]
Hey i have samsung scx4300 please send me software and details my printer shows error "toner exhausted replace toner....thanks
[email protected]
Please forward me the software and details as well. Thanks in advance!!
[email protected] Please forward me the software I have the same problem
PLEASE HELP ME WITH SAME PROBLEM SAMSUNG SCX4300 TONER EXHAUST REPLACE TONER PROBLEM
I am looking for the same software! [email protected]
my ML-1640 samsung is having toner exhaust problem how can i solve..PLz help ([email protected])
my -4300 scx samsung is having toner exhaust problem how can i solve..PLz help ([email protected])
MY-4300 scx samsung i have tonor exhaust problem how can i solve([email protected])
[email protected] pls i have a same problem
You need to open the service menu:
Menu->Copies -> Left arrow -> right arrow ->Menu -> right arrow.
"Rdy Tech" will be displayed. Now press "Menu" then move to "Data setup", then "CLR CNT" , then "CLR all CNT".
Note:This will work only if you had reset you printer with the reset software
Hey i have samsung scx4300 ver.1.21 please send me software and details my printer shows error "toner exhausted replace toner....thanks
HELLO DEAR MY SAME PROBLAMS PLZ SEND ME 1.21 SOFTWARE
[email protected]
[email protected]
same here , can some one send me the the software link [email protected]
thanks
Samsung4300 toner exhausted
Hey follow this steps
1. click on printer menu,copies,<,>,menu,>
2. show ready tech
3. so menu, ok,>,ok,ok clear count
4.then ready
Menu settings no Rdy Tech where
"toner exhausted"
Change the chip
Get new toner
SOURCE: Samsung SCX-4300 printer sows the exhausted toner error
how to sole scx 4300 printer Toner exhausted replace toner problem
SOURCE: Toner Exhausted Replace Toner" scx-4300
Hi
You need to raplce chip on cartridge
Pls vote me to keep me alive
toner exhuasted massage has been seen in sumsang scx-4300 printer , i think in the toner has cartage remain
toner exhausted in samsung scx 4721
https://www.tonercom.net/2019/04/reset-s...
I have same problem.
