Cuisinart SM-55 Stand Mixer Logo
Posted on Oct 20, 2010
The flat mixing paddle is stuck in the mixer and can't be removed from the socket. It turns but when I pull it would not come out.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1825
Points
Here's what really happens. The hook has a shaft screwed into it with bayonet fittings that lock into the mixer. The shaft has a locknut where it screws into the hook. If the locknut becomes loose then the shaft can screw in too far making removing from the mixer almost impossible. Try to get a slim wrench onto the locknut and loosen it off enough to allow the hook to be unscrewed. After the hook comes off, move the locknut down the shaft until the whole assembly can be removed from the mixer. Re-attach the shaft to the hook making sure that the exposed portion of the shaft is long enough to allow for easy removal from the mixer. Tighten the locknut and you will never have the problem again.
  • Anonymous Dec 19, 2012
    Absolutely solved the issue for me. A little additional advice... The nut size is 15mm. You'll need a pretty thin wrench to get in between the mixer and the attachment. THANK YOU!!!.
    Absolutely the issue! Added help... the nut is 15mm & it takes a wrench thinner thana standard box wrench to get between the mixer and the attachment.
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Oct 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
14118
Points
96
Try push it in and then pulling. Try removing it with the machine up side down or try different angles of holding the mixer a slightly shake it to release the mechanical locking mechanism. This is either broken or it is stuck. If you get them out try cleaning inside with alcohol.
I cannot remove the paddle from my Hobart stand mixer. I was making a very large batch of cookies and when I finished the paddle would not come off. I put the paddle on just before starting the cooki
Get some CRC into the top between shaft and paddle socket and in and around that driving lug on the side. Then grasp the paddle with a hand on either side and rock (turn) it back and forth as forcefully as you can until it starts to come free. Eventually it will start to move and you will be able to remove it. Polish the shaft and scrape out the hole, it is flour that has wafted in there that has tightened it up, it packs & embeds itself into the aluminium paddle.
Mixing paddle slips off pin
We have never heard of this problem before. I spoke with our KitchenAid technician as well and he has never seen this problem in the over 20 years of working on KitchenAid mixers.
Are you sure that the beater is hooked on all of the way, and there isn't anything in the beater stopping it from turning and clicking into place? Is the pin stuck? If the pin is not sticking out all of the way, or the spring is bad/damanged it is possible the beater could come loose. You would want to replace the agitator shaft.
Agitator Shaft: http://www.mendingshed.com/kacentershaft.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
2helpful
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
The top of the mixer began shaking and thumping when running, I realized the tilt head is pressed forward a little too far, causing the basic mixing attachment to press too far down into the bowl, maybe by...
Tip the machine upside down on a towel, centralise the hinge pin and tighten the grub screw that locks it into place. This is right up inside the pedestal, there is only one screw there to see.
Now stand it up and fit the mixing bowl & flat paddle, turn the machine on speed one, if the paddle is tinging on the bowl then we now need to set the head height. Turn the motor off.
Raise the motor up and from the front of the machine look in by where the motor hinges on the pedestal. You can see one screw head there. If it's tinging the bowl then you need to turn the screw anti clockwise enough so that the paddle no longer tings on the bowl.
Once it's stopped tinging put it onto max speed and make sure it still clears at high speed, if not turn the screw until it stops tinging. That's it.
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Paddle beater won't push up and turn to release
When you are able to remove the paddle, feel the opposite side of the spindle. It should be smooth. The pin should not stick out the back at all. Carefully, tap it in until it is even with the spindle. That will fix you up, unless the pin itself is also damaged. If so, get a small file and remove any burrs from where the paddle mounts.
3answers
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
9helpful
3answers
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 • Food Mixers
Top Cuisinart Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
