SOURCE: Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
SOURCE: After the cup of coffee has brewed, I no longer
I cant help you but I am having the same problem..I have to turn my machine off to get the brewing light off...
SOURCE: Keurig B70 brews but only brews a little bit,
Check the reservoir to see if it seems warmer than justified.
If so, then the little check valve that causes the pumping action is being blocked by a lime buildup or some other debris particle and not closing when it must to force water into the heating element.
Try pouring some plain white vinegar into the water chamber after emptying, turn the machine on briefly to allow it to start, finally, allow it to sit overnight.
Turn the maker on and pump the remaining vinegar through it without filter or coffee.
Rinse the reservoir out and then run clear water through it to remove any remaining vinegar.
If this didn't help, then the check-valve may have failed and would have to be replaced.
Although I wouldn't do it with a friend's coffee maker, I have used Lime Away instead of vinegar but I don't leave it overnight since this can damage the aluminum of the heater element.
It hasn't so far, but it can.
