Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
