My son knocked my camera off the cupboard in my room and the lcd screen is now black and it shows a crack in it. How can I remove and replace the screen myself with the camera working like new.
I was downloading pictures from my Nikon Coolpix L18 on my computer when I accidently moved the camera and it fell off of my desk. The screen shows a shatter. Is there any way to fix this? I was downloading pictures from my Nikon Coolpix L18 on my computer when I accidently moved the camera and it fell off of my desk. The screen shows a shatter. Is there any way to fix this?
You can't post conmments that contain an email address.
You need a set of philips screw drivers size #0,#00 and #000. Buy parts camera with stuck out lens but good lcd from ebay. Then replace the lcd screen and the led back light assembly connected by flexible circuit and flip up connector.
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
You are correct. The LCD screen is broken. This is super common with the C743. It is unprotected and unlike most LCD's, there is no hard plastic or glass screen over the LCD. My wife broke my son's 1st 743 when she left it in her bag. My son broke the second one by packing it in his duffle bag for a summer camp trip.
You can spend about $40 for a replacement that will probably break again, move on to another camera or use this as a "green mode only" point and shoot camera just like the old days where you don't know what you got until you get home. You can still hook it up to your TV set to change the settings and review your pics, but that's all you are left with.
Assumed that LCD screen is black and what about Eye piece viewfinder? Does it show picture to you?
If LCD Screen is black, it means it has no back-light. check any button to turn back light on & off at LCD portion.
There can be an other reason of black LCD. a flexible cable which connects LCD and Camera circuits and it can be broken/ cracked/ out of order.
No.. most likely the ribbon cable that connects the lcd screen to the rest of the ds has been damaged or knocked loose. Or the circuit board somewhere has been cracked or damaged, affecting the circuitry that sends a signal to the lcd screen.
Is it under warranty? You can maybe send it back to Ninendo for repair. Or open it and attempt to repair it yourself. Otherewise I'm afraid the DS is just broken...
I have a DSC-P93 (same camera with 5mp) I had crack the LCD carrying the camera in my front hip pocket. I searched for a replacement LCD and I had no luck. I ended up Buying a “parts” camera from ebay for $9.90 + 4.00 for shipping. You could get either DSC-P73 or DSC-P93 (the LCD is the same) just be sure they say that the screen shows something. Menus is fine errors are no problem as long as it’s not black.
That is definately a cracked lcd your describing! I doubt there is an easy solution but maybe...
If you are able to get into the menu and disable the LCD that might help.
However! The fact that the LCD is broken shouldn't keep the camera from running (though its remotely possible)
If you can't shut it off or work without it the odds are you've got an expensive paperweight.
At least thats what I gather based on your description.
I have the same problem... model Sony H5
