SOURCE: refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
SOURCE: Maytag MF12568AEW (white) Problem
For temporary relief of problem, disconnect power to front panel. The connector is located under the left door hinge cover on top left of refrigerator. Unscrew cover to remove.
Call Maytag, 1-800-688-9900, try to get the automated system to connect you to a real person (try saying "representative"). Explain to rep that you are aware this is a common problem with the HV Control Board - Part number: 1206507. Maytag is aware of this issue and said to me that this is an "improved" part. For me, they shipped the part out Fed Ex and set up a time for a serviceman to come out and fix it - all at no charge. I didn't want the hassle of waiting around for a repairman so I replaced it myself. It's pretty easy. The part came with instructions for programming. Here's the steps to replace if you want to do it yourself. *** I'm not a professional. Do this at your own risk. ***
Repair:
1. Pull the fridge from the wall and unplug it.
2. Wait 15-20 minutes
3. Remove the screws securing the HV circuit board cover on the left
rear side of the fridge. (left as if you were facing the rear of the
fridge)
4. Remove the clear plastic cover.
5. Verify that the fridge is unplugged.
6. Remove the 4 wiring harnesses from the circuit board. Using your
finger press down on the locking tab while gently pulling the wire
harness out.
7. Once all the wires are free, remove the circuit board by pressing
back the plastic retaining tabs while gently pulling the board out.
8. Insert the new board oriented the same way as the old. The board will snap into place.
9. Reconnect all 4 wiring harnesses.
10. Replace the clear plastic cover
11. Replace the steel cover and secure with the 4 screws.
12. Program the new circuit board according to the included
instructions. Programming requires that you enter a specific number
listed on the inside of your fridge into the front panel, this in turn
programs the board. Without this step, the fridge will not work. It's the number after CODE on the tag that includes model/serial number
Programming Mode:
1.Press and hold the Door Alarm Keypad.
2.Press and hold Freezer Temperature Down Keypad.
3.Release the Door Alarm Keypad and wait 3 seconds.
4.The control will display PE to indicate the programming mode.
5.Entry is confirmed by pressing the Freezer Temperature Down Keypad - once more.
6.The
control will display the current Program CODE.The value should be
validated with the Program CODE printed on the unit serial plate.
7.Press the Refrig Temp Up Keypad or Refrig Temp down Keypad to change the digit value with each key press.
8.The decimal point indicates the selected digit. Press the Freezer Temp Up keypad to select the next digit.
9.Once
the desired Program CODE is displayed, press and hold the Freezer Temp
DOWN keypad until the Program CODE begins flashing indicating it has
been saved.
SOURCE: Maytag refrigerator clicking noise and stopped working
Mine is P mds2651 HEB.
Same Problem.
Home Depot and Maytag ****.
SOURCE: why does my maytag plus refrigerator have constant humming
sounds like u might need a overload relay check with your local maytag store might be part of recall
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
