SOURCE: Problems with Jacuzzi BM06959 Era One-Piece Elongated Toilet
Here is a store front that sells that unit. It is Bob Villa's own website. I am sure they can fix you up.
Good luck and let me know if you have trouble getting the ifo you need.I have a contact at Jacuzzi that I will get hold of if this doesnt work for you.
http://www.bobvila.com/SmartBuys/Jacuzzi_BM06__Era_1_Piece_Elongated_Toilet-p466002.html
SOURCE: Jacuzzi BK37959 can't install Floodsafe auto-shutoff toilet conn?
just remove the filter, it will work properly
SOURCE: please tell me how to get more water in my toilet
The water level in the bowl is determined by the built in trap in the back of the bowl. Water is allowed to enter the toilet and it then "over flows" the p trap in the back when flushed. Once it's flowing, it syphons the water out of the bowl. While the tank is re-filling, a small portion of water should be running down the overflow from the small hose clamped onto the overflow This rinses the inside of the bowl, as well as helps-refill the bowl. Be sure that hose is directed inside the overflow tube. To see what the max water level in the bowl can be, add some water from a cup or glass. Once it's full you can keep adding and it won't get any higher. This will be the max level you can expect.
SOURCE: Need to order a replacement toilet seat for Model
I have problems with booths of my toilet seat.
When sitting down it move's & every think is tide .
My question is WHY ?????????????? It is also very unsafe, you feel like you will fall of the seat.
SOURCE: Jacuzzi BK37959 White Era
Is there a good flow from the small feeder tube going into the center tube the flapper mounts to? It is possible your flush assembly has mineral deposits,rust,calcium,etc. build up and is not allowing sufficient flow through that tube to rinse the sides of the bowl. You could also Try dumping undiluted C L R (calcium,lime,rust) cleaner into that tube and allowing it to clear the passages. If the passages are blocked you will notice the water flooding back out of that central tube in the tank and may be able to use a small inspection mirror and a piece of baling wire to clear the exit ports around the rim of the bowl. You may also be able to clean the entire flush assembly by removing the water line from the bottom of the tank then removing the flush assembly and soaking it in C L R for a half hour - or, just replace the entire assembly. I hope this helps!!
